Keyboard Preferences
From Audacity Manual
Jump to: navigation, search
Préférences de clavier Tastatureinstellungen
Keyboard Preferences sets the keyboard shortcuts which can be used for numerous commands in Audacity as an alternative to using Menus, Toolbars or mouse gestures.
Audacity comes supplied with a default set of shortcut bindings but these can be added to, changed or removed here if desired.
Devices PreferencesPlayback PreferencesRecording PreferencesQuality PreferencesInterface PreferencesTracks PreferencesImport/Export PreferencesExtended Import PreferencesProjects PreferencesLibraries PreferencesSpectrograms PreferencesDirectories PreferencesWarnings PreferencesEffects PreferencesMouse PreferencesModules PreferencesKeyboard Preferences: list of commands and shortcuts and control buttons
Click on any of the other Preferences sections in the above image to go directly to that Preferences page.
A full list of the commands with their default key bindings is also available at Keyboard Shortcut Reference.
Key Bindings
Category:
Use this menu to view:
  • All key bindings (the All choice)
  • Key bindings associated with a particular menu
  • Key bindings not associated with any menu item (the Command choice).
Command/Key Combination list
These headings list all or some of the commands which can be attached to keyboard shortcuts, together with their currently allocated shortcut or "binding", according to the Category choice above.
When "All" is selected from the Category menu, the commands list
  • Commands associated with the various menus, listed in the order in which the menus appear (left to right) in the Menu Bar
  • Commands not associated with any menu
    • Cycle through Dock, Track View and Selection Bar
    • Tools Toolbar
    • Transport Toolbar and associated Play commands
    • Additional Delete keys
    • Seek during playback
    • Move and toggle track focus
    • Move cursor
    • Adjust selection regions
    • Track Control Panel and Track Drop-Down Menu commands for focused track
    • Snap To
    • Full Screen on/off
    • Adjust output gain
    • Adjust input gain and source
    • Adjust playback speed.
If you are looking for a particular command in the list and know its exact name, you can jump to it on Windows or Linux by typing the first letter of its name until you reach it.
Gale 03Oct11: Seeking by letter isn't working on Mac, see http://bugzilla.audacityteam.org/show_bug.cgi?id=236
Input box, Set and Clear buttons
Gale 30Oct12: Wrapping the ALT GT text in an editornote as it is not correct, at least in Windows 7. It's true that Windows now allows CTRL + ALT (instead of ALT GR) to type alternative characters because some keyboards may lack ALT GR or right ALT, but entering ALT GR and a letter in Keyboard Preferences enters CTRL and that letter, and does likewise in Winamp, Foobar and VLC Preferences. I will check on XP later, or someone else please do so.
  • Peter 6Nov12: On my XP desktop this seems to work ok - and seems to work ok on my W7 laptop too ??
  • Gale 13Dec12: It looks as if I had a scancode problem in my registry. I had not done any keyboard remapping but ALT GR was producing CTRL. After resetting the registry with KeyTweak and rebooting, ALT GR produces CTRL + ALT. So I reinstated the text and removed the ToDo.
  • To change or add a binding:
    1. Click to select the item you want to change in the Command/Key Combination window. The current key combination for that command (if any) will now appear in the input box to left of the Set button.
    2. Either click in the input box, or press TAB once to switch focus to it.
    3. Choose your binding by either holding any modifier key (or combination of modifiers) then pressing any non-modifier key, or press any non-modifier key on its own. Valid modifiers are:
      • SHIFT
      • CTRL ( CMND on a Mac)
      • ALT
      • ALTGR or Right ALT (on Windows keyboards, this key sends a combined CTRL + ALT modifier and can thus be used as an alternative to call any binding that includes CTRL + ALT).
      As an example, SHIFT + 6  or CTRL + SHIFT + P  are both valid bindings. Your chosen key or key combination will now replace the previous content of the input box. Note: you cannot set the main system shortcut for Escape (ESC on Windows or ALT + C on some Linux systems) as a binding.
    4. Click Set to apply your desired change. If your chosen key binding is already allocated to a command, Audacity will inform you and let you enter another binding instead.
  • Clear: To remove a binding, select the item as above, then press Clear.
Export..., Import... and Defaults buttons
  • Export... and Import...: You can export and import key bindings (for example to keep a safe copy of your custom settings, or to transfer them to Audacity on another machine). Export... exports your bindings as an XML file, and Import... imports the XML file back again. You can also edit the XML file in any text editor and re-import it, as an alternative to editing the key bindings in Preferences.
    Note that shortcuts for Generators, Effects and Analyzers where you have to add your own key binding are not currently exported.
    Note also that Audacity does not check for bindings which are allocated to more than one command when importing the file, so edit carefully. The only entries you can usefully edit are the actual key bindings themselves which are in the "key" string at the end of each command. For example, to set the key binding for "New" to SHIFT + N, the command in the XML file should read:
    <command name="New" label="New" key="Shift+N"/>
    Be sure not to delete the closing "/>" characters at the end of the command.
  • Defaults: Clicking the Defaults button reverts all bindings to those when you first obtained Audacity. This button is handy if you decide you have not got your changes right and want to start over again.
OK and Cancel buttons
  • OK: When you have completed your edits press the OK button to save the new bindings and exit the dialog.
  • Cancel: If you press the Cancel button this aborts the editing and all bindings will remain as they were before you started to edit them and the dialog will be exited.
Personal tools
