Tutorial - Recording Multi-track Overdubs
From Audacity Manual
Jump to: navigation, search
Tutoriel - Enregistrement d'overdub multi-pistes Tutorial- Grabando pistas sobregrabadas
This set of tutorials describes known, good, working methods of creating a multiple sound track overdubbing session in Audacity. That is, you record one track and then play it and add a second track against it -- drums, guitar, voice; repeat as needed. You will be able to hear a mix of your live recording and the previous tracks simultaneously in your headphones (also required).
Generally, purpose-built hardware is needed to hear your live recording without unacceptable playthrough latency - without that hardware you will hear what you are recording too late. Failing that, a method for overdubbing using your computer's on-board sound card is given too.
Multi-track overdubbing
This tutorial is a generalized tutorial on multi-track overdubbing.
Tutorial - Multi-track Overdubbing
For specific cases of working with different hardware setups please see below.
Overdubbing with specialist hardware
The following tutorials are all to be found in the Audacity Wiki. They explain the creation of multi-track overdubs using three different specialist hardware configurations.
  • A USB microphone pre-amp with one XLR microphone input and a mini-jack headphone socket.
Overdubbing with a Shure® X2U Microphone Amplifier-USB Adapter
  • A stereo, line level, USB external sound card (2-channel USB/Audio Interface).
Overdubbing with a Behringer® UCA202 Stereo bidirectional USB Sound Card
  • A USB microphone.
Overdubbing with a Samson® G-Track USB Microphone
All three have been hands-on tested. They can be made to work on Linux®, Mac®, and Windows®.
Overdubbing using your computer's on-board sound card
This tutorial, also in the Audacity Wiki, is designed to help if your equipment does not have hardware playthrough and software playthrough is not an option. You may not be able to hear yourself during the recording.
Further Help
If, no matter what you do, the show sounds terrible or doesn't work at all, drop in to the Forum where we can try to help you further. Registration is required to post and you may need to wait before your posting appears.
At minimum, you will need to tell us: exactly which version of Audacity you are using (that means the full three-part number, for example 2.0.0), what kind of computer you have and which operating system it uses. Don't head straight to the details of the problem without telling us what you're producing and why. Be prepared to tell us how the straight recording session went - the one you did before you tried overdubbing.
Help > Audio Device Info... may give us useful diagnostic information, but if you post it, please post it between [code] [/code] tags.
Personal tools
